Sheet Metal Flat Pattern
zaneFBY4D
zaneFBY4D
Hello all, I am currently working on a bent up fence that attaches via tabs at the end. The tabs overlap the slots in the model since when the part is machined I want there to be overlap so the tabs will hold in the slots. The issue is since they overlap I get the error "Topology belongs to more than one bend". I want the model to be accurate but also want to be able to show flat pattern. Any solutions?
Thanks!!
Gabriel_Watson
Have you tried creating the flat pattern first, then editing on the flat pattern environment to add the tabs? Maybe just create your sketch on folded and right-click it to "Copy to flat pattern" so you have the dimensions on the flat.
