Sheet metal defaults
Hi all, any help would be very much appreciated on this... im pulling my hair out! Thank you in advance!
Ok, we use inventor to draw sheet metal parts of different materials and different thicknesses. We also have a CNC pressbrake which has different tooling on, e.g top tools have either 1mm, 1.5mm or 3mm radius... and the bottom tool V's are 10mm, 16mm, 24mm etc etc.
How is the best way to setup the sheet metal defaults?
On the press brake's bend table it says if i fold the same material, but to different angles, then i will get a different bend radius.. but in the sheet metal rules.. i have to set a bend radius... What radius should be put in here? This radius changes with the angle, so this bend radius should come from the bend table.. not a fixed value in the sheet metal rule?
Do i need each material and thickness setup as individual rules, and unfold rules for each individual material and thickness... do have a rule for each press brake tool i could possibly use??
Im very confused so any help would really be great.
Thanks very much,
Best regards, Simon.
