Sheet Metal curved then bent with complex shape
davidneshat
davidneshat
I have attached a picture of the finished part in this post.  It is made from 16 gauge sheet metal that is cut to shape, curved to a radius of ~4.4 then has the tabs on the side bent down at a 90 degree angle.
I cannot figure out how to model the complex shape in a curve or how to curve the complex shape at a 4.4 radius.
Thanks for looking.
johnsonshiue
Hi! I think this can be done by using Contour Roll command. You need to create a profile like a C and then define a vertical line. Use Contour Roll command to create the rolled shape. Then create the cutouts on the planar faces.
Many thanks!
Software Test Engineer
CadManagerMoffatNZ
David
Hi and welcome to the forums.
Here is a quick part showing the use of the Lofted Flange command.
Hopefully it is close enough to your part for you to use as a "rough" guide of the features to use.
Inventor "currently" really only unfolds planner surfaces so it won't work with a curved surface as shown in your example (hopefully only it will soon).
Have a look at the Lofted Flange model i have attached and feel free to ask any other questions.
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Daren
Dell Precision 7720 + P3418HW
Windows 10
Product Design & Manufacturing Collection
Inventor 2021.0.1, Vault Professional 2021, Showcase 2017
SBix26
In the photograph you attached, the part is not a smooth curve, but has noticeable bends between the tabs.  Modeling the part this way would allow Inventor to unfold it (attached file is 2019 format):
Sam B
Inventor Pro 2019.2 | Windows 7 SP1
LinkedIn
CadManagerMoffatNZ
David
here is a quick contour roll example as suggested by Johnson.
As you will find yes it looks better than the lofted flange but its "nasty" to model.
Daren
Windows 10
S_May
Hi @davidneshat,
After the lasers you will be disappointed
the rolling will not work
the upsetting of 17,29mm to 23,22mm will not work
it must be created as from @SBix26
2018-11-28 07_43_52-Autodesk Inventor Professional 2019.png2018-11-28 07_44_10-Autodesk Inventor Professional 2019.png
davidneshat
Hi Johnathan,
Your statement: You need to create a profile like a C and then define a vertical line.
- I created a c-shape that I want.
- I have a vertical line but what do you mean "define a vertical line"?  I have a vertical line but it does not help in any way I can see.  My ?s are:
  > Solid line or a reference line?
  > Should it be in the center of the C?   Cross the C shape? Be at the end of the C shape?  90 degrees to the C shape?
  > Attached to the C shape some how or somewhere?
  > Is the vertical line the axis for the Contour Roll?
Can you be a little clearer, maybe an example.
Thanks, Dave
