Inventor Forum
Sheet Metal Bend Problem
8 REPLIES 8
Message 1 of 9
363 Views, 8 Replies
See attached part file. The bend is in the correct place/orientation etc but it has trimmed the part perpendicular to the bend. Is there a way to prevent this?
8 REPLIES 8
Message 2 of 9
You can use a flange as in the example attached.
~Larry
"StuartMoore" <nospam@address.withheld> wrote in message
news:24962510.1077107627540.JavaMail.jive@jiveforum2.autodesk.com...
prevent this?
Attachment not added (too large): "YokeSM1.ipt"
Message 3 of 9
Thanks Larry but your attachment was too large. Can you zip it?
Message 4 of 9
It's only 242 k but the problem is more likely it's an R8 file. Don't have R7 loaded. ~Larry "Larry Caldwell" wrote in message news:40335dce_3@newsprd01... > You can use a flange as in the example attached. > ~Larry > > "StuartMoore" wrote in message > news:24962510.1077107627540.JavaMail.jive@jiveforum2.autodesk.com... > > See attached part file. The bend is in the correct place/orientation etc > but it has trimmed the part perpendicular to the bend. Is there a way to > prevent this? > > >
Message 5 of 9
Here's a solution, maybe what Larry was talking about
news:18916990.1077118070687.JavaMail.jive@jiveforum2.autodesk.com...
Attachment not added (too large): "YokeTemp.zip"
Message 6 of 9
Thanks Mike. ~Larry "MikeC" wrote in message news:403397f7_3@newsprd01... > Here's a solution, maybe what Larry was talking about > > "StuartMoore" wrote in message > news:18916990.1077118070687.JavaMail.jive@jiveforum2.autodesk.com... > > Thanks Larry but your attachment was too large. Can you zip it? > > >
Message 7 of 9
Thanks Mike. That's just what I want.
Message 8 of 9
:) "Larry Caldwell" wrote in message news:40339c67$1_1@newsprd01... > Thanks Mike. > ~Larry > > "MikeC" wrote in message > news:403397f7_3@newsprd01... > > Here's a solution, maybe what Larry was talking about > > > > "StuartMoore" wrote in message > > news:18916990.1077118070687.JavaMail.jive@jiveforum2.autodesk.com... > > > Thanks Larry but your attachment was too large. Can you zip it? > > > > > > > >
Message 9 of 9
:) "StuartMoore" wrote in message news:8165689.1077126417086.JavaMail.jive@jiveforum1.autodesk.com... > Thanks Mike. That's just what I want.
