Is there any way to consolidate like bends in a bend list? For example: In the attached picture, bends A, B, F, I, J, Q, R, V, and Y are identical. I could manually modify the table and view to reflect this but i am curious if there is a way to automatically do this and have the Bend ID labels in the view reflect it as well.
Inventor 2017
All Hot Fixes and Updates installed
Solved by Yijiang.Cai. Go to Solution.
Nope..
There is no way to get it done automatically. But there are two ways to get it done -
1. If we know the bend info in the flat pattern, you could modify the bend ID in flat pattern using bend order annotation to get the expected result.
2. You could export the bend table to excel, and use the excel to quick handle the expected result, and insert the excel table again.
