Inventor Forum
Sheet metal bend lines
2 REPLIES 2
roloNCC
130 Views, 2 Replies
Hi everyone.
Does anyone know how to set up bend lines colors. I typically make parts that have 90degree flanges going up or down. When I convert into a dxf this bend lines are represented under a "bend line" yellow layer. I would like to customize that so that bend lines up are a certain color and the bend lines down a different color. Thanks
Labels (1)
2 REPLIES 2
kacper.suchomski
in reply to: roloNCC
Hi
S&SE -> Layers and Standard
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
blandb
Right click on the flat pattern> Save Copy As>dxf > Save
Choose Layer Tab:
Set the Bend and Bend Down:
You could write some ilogic go scan an assembly and do all this for you, or have it run on save and create the dxf with these settings vs. needing to do it manually each time.
Autodesk Certified Professional
