Sheet Metal angle vs model don't match
leblanc2024
leblanc2024
Hello All,
I'm having an issue where the bend angle of a flange doesn't match the model.
I added a 30° angled flange to my model and get an angle that isn't even. I tried recreating the part and variable angled cause this issue.  At 90° I get an exact angle. Please let me know there is a fix to this or if I'm doing something incorrectly. Thanks in advance.
Ivon
"You don't know if you can unless you try!"
Replies (8)
admaiora
Can you attach the part?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
leblanc2024
Hello @admaiora,
I have attached a file with the same issue.
Ivon
admaiora
No issue in your model from my side
What's your release/build? Have you installed all the updates/service pack?
Admaiora
leblanc2024
Hello @admaiora,
I have my precision for measuring to the max.  Maybe that's my issue and haven't noticed it till now.
I working with Inventor Professional build 287, release 2022.2 - Date Sub 10/24/2021 64 bit edition.
Ivon
admaiora
Yes,
Now I see, that's the issue.
It's just a normal approx
Admaiora
mcgyvr
Internally Inventor uses radians I believe...
When you convert back and forth you see this when taken out to that precision.
leblanc2024
Thanks @mcgyvr and @admaiora,
I thought I was messing up somewhere.  I just haven't used the all decimal measure on folded parts before... Only machined parts.  Now life can go back to normal. 🙃
Ivon
johnsonshiue
Hi! There is indeed a change in behavior in Angle Measure on 2022.2. It seems that the numerical noise is being reported. It does not affect the model accuracy but it does look odd. We are investigating the issue (INVGEN-59610). Hopefully, we will find a good solution soon.
Many thanks!
Software Test Engineer
Type a product name
