SHEET 2 TITLE BLOCK INFO
Steve_Bahr
Steve_Bahr
Greetings.
I've created a custom drawing template that contains a custom title block.  The title block is populated with model iProperties when the first drawing view is plunked down onto the first sheet.
How can I get the same iProperty info from the first sheet into the title block on the second sheet without adding a superfluous drawing view?
Thanks in advance and Happy Friday.
Steve Bahr...since 1962.
______________________________________________________________
Please mark this response as "Accept as Solution" if I was successful in answering your question.
mdavis22569
Not without some coding, or another custom Titleblock that would pull the information in
I always just make a new sheet ..and throw a few off of the sheet if I need it to match.
Mike Davis
Steve_Bahr
We do the same thing re: add a superfluous view; not the best solution.  I don't code and don't have that resource available to me.  I thought there might be a simpler solution.  Thanks for your response.
