Sharing same local work space for Vault Workgroup and Inventor
In an effort to become more organized I've attempted to map my Vault projects in Workgroup to the same local location as my local vault projects via the Inventor.exe application.
It seems to me that if Inventor.exe is open, i cannot open a file from the Vault Workgroup application as it will attempt to overwrite my local .ipj with that inside the vault. If I then close inventor.exe, the parts are loaded successfully.
To me the act of merging locations between the Inventor.exe application and the Vault Workgroup application seems intuitive, reduces file space, reduces hassle involved when using "save-copy-as" as the workspace location is constant between applications. I've even done minor testing with other users and they don't seem to have issues.
My question is more trying to understand how the .ipj works and if it is a "smart" idea to map both applications workspace upon each other or am I going to run into some issues down the line. I'm surprised the default between these two applications isn't to act this way so I must be missing something.
Am I correct to assume the .ipj stores file path information "relative" to where the .ipj itself is located? I've also noted that locally there are .ipj's in the Vault Workgroup default project directory as well as within the immediate project folders as well. This behavior seems odd.
