Shape Around Cone
Shape Around Cone
hugogomes
Shape Around Cone
hugogomes
Hello Guys,
I've a client that wants to cut the shapes on the render image of this christmas tree.
Having a cone drawned in inventor it's easy, but how can I have those shapes to contour the cone and then have then flattern so that I can send them to laser cut?
JDMather
Q1. What version of Inventor are you using?
j.palmeL29YX
Attached a rough idea ...
(IV 2020)
HTH
If my reply solves your problem, click the "accept as solution" button. This can help others find solutions faster
Jürgen Palme
johnsonshiue
Hi! There are multiple ways to do this. You can create a workplane tangent to the cone. Create a sketch and draw the curves. Next, project the curves to 3D Sketch (wrap around). Split the cone face using the 3D curves.
Or, you can use a Sheet Metal part. Create a Contour Roll using an angled line revolving a vertical line. Unfold it and create the 2D curves. Split the planar face using the 2D curves. Lastly refold it back.
Many thanks!
Software Test Engineer
