Announcements
shaded view on print are shown wrong
carstn
carstn
Hi
We have 2 Inventor-users(ot of 68) that are experiencing some odd print-out behavior from Inventor.
When printing drawings containing shaded views, the shading is shown awkwardly. see pic.
This is a periodic error and after a restart of Inventor - everything is ok again.
problem occurs og both ordinary print and print/export to pdf.
What is causing this behavior and how do we stop it from happening?
/Carsten
PDSU 2016, Vault pro 2016. Win 10
All settings from common scripts.
Replies (14)
mcgyvr
With a drawing open (and do this for the template they are using also and save it) Tools...document settings..drawing tab... set Use Bitmap to "Offline Only"
johnsonshiue
Hi! Does this behavior happen to the actual print or you see it on the screen in Inventor? Could you try setting Tools -> Application Options -> Hardware -> Conservative mode and restart Inventor? I suspect it can be hardware related but I am not sure. Also you may want to update the graphics driver for those machines.
Many thanks!
Software Test Engineer
mcgyvr
Many thanks!
Yeah looking at it again it does seem to be more than the normal "Offline Only- Bitmap" issue that many experience..
carstn
Hi Guys
It is on the print only, never on the screen - well, only when it is pdf-export Smiley Wink
It can't be the Document settings option, because it prints fine on other computers.
I'll have a look on the graphics drivers and see if that's the bug.
Funny thing that is fine after a restart of Inventor...
/Carsten
I have the same issue.  It doesn't matter what printer I use, it happens when I print to a PDF.  I tried conservative mode and a restart with no change.
mcgyvr
So I'll assume you have an adobe virtual printer right?
If so go to its "printing preferences" and set it to "high quality print"  as shown..
Did that help?
Thanks, that worked for me!
mcgyvr
Did that help?
@carstn Not sure if this is the same problem you are having or not... If so please try that..
Update: It also happens when I print to a Xerox plotter 6204 Wide Format.  Is there a list of supported plotters?  I get the same problem with PDF's - I am have the full version of Adobe Acrobat Pro and use it to create PDF's.
If I export to a PDF it works fine, but if I try to plot to a PDF it fails.  What are the differences between export to a PDF and plotting to a PDF?  What controls the export settings?
SBix26
Plotting to PDF using Adobe Acrobat, you will need to set the quality to High instead of Standard (going by memory here).  With the default quality setting, you will get banding in shaded views.
Edit: sorry, I didn't read the previous messages in this thread before replying.  @mcgyvr gave you the settings needed for printing/plotting using Adobe's virtual printer; are there similar settings for the Xerox plotter?
Sam B
Inventor Professional 2018.2.3
Windows 7 SP1
Thanks for responding.  Even with high quality, I still get issues:
Using the highest settings, the Plotter got better, but not right.  I still have the shade offset from the part edge lines.
Anyone have any suggestions?
mcgyvr
I'm really not seeing a problem there (except for the few white lines that look like sections of the shaded are offset a bit..).. Is that what you are talking about?
Did you try the other setting I first talked about (use bitmap only)?
Also what version of Inventor are you using and have you ensured its fully up to date with all updates?
Also have you tried updating your graphics card driver to the latest version?
Also what version of Adobe are you using?
@mcgyvr thanks for the reply.  I had already switched to bitmap offline only.
The white lines are the issue on the PDF.
Inventor 2018.2.3 1-16-2018
Adobe Acrobat Pro DC 2018.009.20050
My video card has an update, ill try that.  Would the video card have any impact on the plot?
I have the latest plotter drivers.
Updated video card drivers and nothing.  Still get crazy lines across the shaded view.
