Announcements
Shaded Drawing View - shading disconnected from outlines
william
william
Hello Everyone
I have noticed a glitch in shaded drawing views that occurs periodically.
The shading seems to be disconnected from the outlines. If I grab & drag the drawing view it will update and display normally, likewise if I double click the drawing view and exit again without changing anything.
Sometimes it can occur on only one page in a multi drawing set, without checking through all of them there is no way to tell. I cannot reliably reproduce this issue. Has anyone seen this behaviour before? And Any ideas as to what causes it.
Could this be a hardware/graphic issue? or a setting or workflow?
The closest thread I could find on this issue is https://forums.autodesk.com/t5/inventor-forum/shaded-view-on-print-are-shown-wrong/td-p/6964475 but not sure if it is the same problem.
mcgyvr
@william  Yes stuff like that is posted about/reported quite often..
Typically a very good idea to ensure you are using the latest graphics card driver from the card manufacturers site and stay up to date with them.. Beyond that good luck 😉
johnsonshiue
Hi! It looks like a view port or graphics corruption issue. Open the model file and do Rebuild All. Or, right-click on the drawing view -> Make View Raster. Then repeat the step ->Make View Precise.
It could be graphics driver related. Please make sure all critical Windows updates are installed and graphics driver is updated.
Many thanks!
Software Test Engineer
pumpkinboss
Please ignore this post.
