Setting/Rewriting Sequential Ordering
Anybody ever have the issue with sequential ordering on a manual set up bend table/ordering where after setting the bends its repeats a single number on a couple of the bends.
My example is after re-setting the bends on the flat pattern (about 3 times) the order repeated bend 13 on bend 11,12,13 (all three notated at 13). I ended up having to clear the repeat instead of just re ordering thru the checking on and off of sequential ordering on drop down mouse menu (right click).
Is there any other way around this? As this was rather inconvenient. I only want static values though. No manual overwrites on the  .dwg files.
blair
No, is it possible to post the file. Something's not right.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
johnsonshiue
Hi! Please share an example here. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Here are some screen shots i was able to take. In the order of procedure.
The first/auto bend table produced. Not the best in this scenario.The first/auto bend table produced. Not the best in this scenario.set sequential order from the bend table tab in the model. make a mistake and miss 7 and 8.set sequential order from the bend table tab in the model. make a mistake and miss 7 and 8.Go back to reset the numbers and then bend 11 and 12 change to match.Go back to reset the numbers and then bend 11 and 12 change to match.7 follows what happens to 8 bend on change.7 follows what happens to 8 bend on change.the error shows in the prints.the error shows in the prints.
fixes only on clearing of bend table on model annotations in flat pattern. then re apply each bend.fixes only on clearing of bend table on model annotations in flat pattern. then re apply each bend.
johnsonshiue
Hi! I believe there is a bug here. But, the images do not help me understand the issue. Could you share the Inventor files (ipt and idw/dwg)?
Many thanks!
Sorry Josh,
I work with a company and our parts are confidential.
If you would like however I can help you with a step by step instruction on how i created a similar part thru sheet metal design and how the steps I've taken have caused this error to occur.
johnsonshiue
Hi Craig,
Please send the files directly to me (johnson.shiue@autodesk.com). I can sign NDA if need be. We work with various customers worldwide. Your data is as secure as ours.
Many thanks!
