Setting Boolean as key
Hi forum,
I'm stuck on something. I've made a parametric model of a electric motor.
Theres 3 user inputs needed to form a final configuration;
Power x [kW]
Flange size x [mm]
Brake [y/n]
I've set keys to power and flange size, these work fine. But i can't set a key for the brake option for some reason.
I've designed it as follows;
The brake options decides the length of the backside of the motor, so i've made a boolean for brake, true or false.
Then i have the total length of the backside of the motor = waaierkaplengteresult
I've made a rule;
Now when i use the boolean in my parameter list it all works fine, the model adjust according to the parameters i have set.
But for some reason i cant find the boolean in the tree of when i want to create an iPart, see picture below
Both the power and flange size are there, aswell as the lengths, but not the boolean?
I guess im either looking in the wrong place (less likely), or the way i've designed it is simply not the way it's supposed to be used (more likely haha). I'm a bit of a newbie when it ilogic etc. Any advice or tips are welcome.
Thank you in advance!
