Announcements
Set an assembly inseparable
I have an assembly, let's say for example, "hello.iam" and its parts "hello_1.ipt", "hello_2.ipt", etc...
Is there a way to set this assembly to be inseparable? From the file itself?
Because we use it from a library folder... Can't do it from other "iam".
I was thinking about make it like a welding, but it gets immovable...
Hope I was clear... Thanks!
blair
Any sub assembly within an assembly is inseparable unless you step down into the sub assembly and edit it. You could either move the IAM file and it's components to a Library Folder. Or try changing the security setting for the IAM file to Read-Only.
Possibly move it to the Library and when you place it into your current IAM file, set it to flexible.
Not really clear, just taking a guess as to what you what.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
mcgyvr
Not really clear..
But in Inventor you set an assembly to "inseparable" by opening your assembly and going to tools..document settings.. bill of materials tab and changing its default bom structure to "inseparable"
This help document talks about the different bom structures available in Inventor.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Inventor/files/GUID-A0A95805-CBF6-4524-8314-4AC8B53C19CF-htm.html
I suspect thats not what you want though..
Thanks! That was what I was looking for...
Sorry for the unclear post...
