@ToddPig wrote:
This is what make Inventor so confusing and hard to learn. If you take two parts (*.ipt) and put them together they become an assembly (*.iam). But when you want to select and assembly in a presentation file, they use the term "component" instead of "assembly". And to make it worse, just below the selection for "part/component" is another drop down selection for "All Parts / All Components / Single".
If somebody told me Autodesk did things to confuse their users on purpose, I would have a hard time arguing against it.
@ToddPig When talking about selection filters a "component" can be a part (ipt) or an assembly (iam). (I believe thats is definition too.... basically a part or element of a bigger thing)
"Part" is always a single part (ipt).
My ERP system also uses "Component" to refer to parts or subassemblies.
I'm curious..
How would you perform the same type of functionality in Solidworks? Do they have a part and an assembly selection filter?
How do you quickly select a part and an assembly to apply the tweak or turn of visibility or whatever to both at the same time? (must you switch selection filters to accomplish that task?)
