I have seen selection filter and apply selction of faces and edges.
I want to leverage this further. In a part, is it possible to simply drag a window and have inventor select all faces?
@DRoam wrote:
But then, in regards to tackling the verb/noun selection for all commands..... @SteveMDennis, as you know, we want consistency Wait until it's realistic to prioritize this issue and address it as a whole. Then make a list of every Part-environment command that allows multiple non-contiguous selections, and knock them all out. And then that can actually be a headline for that release: "Window selection enabled for all Part commands!" (rather than trickling it out bit by bit and just making people mad that it works in some places and not in others).
And I wonder if while you're at it, you could modify the selection "architecture" for Part commands such that, in the future, it's easier make blanket changes to all commands like this when good ideas come along? Basically, clean up all that nasty, bloated, dysfunctional "history of Inventor's evolution" that forces you to change every.... command... one.... by one.... and do it right, unlike those before you Is that realistic? Or no?
To knocking it out as a whole, I doubt that it would every bubble up to the top partly based on the cost... This would be a huge project. There are 1000s of commands believe it or not.
As far as the architecture, that is what makes it so expensive, doing it right! The reason we can do a few commands in each release is because we are not roto-tilling the entire command architecture. The cost is low and the risk is low but we can't "address them as a whole" this way...
All that makes sense, thanks for the info! And I had no idea there were thousands, I would have thought dozens....
Thanks for explaining.
Still, what do you think about the noun/verb selection? Do most (or all) commands support noun/verb selection? I just checked an all of the ones listed or mentioned as top-priority in this thread do! And I checked a few edge commands (chamfer, fillet), feature/body commands (move bodies and the Pattern tools), and even Direct, and noun/verb selection works for all of them! With a few caveats...
But even if those weren't addressed, noun/verb selection works perfectly for nearly all (typical) commands as-is. So would it be possible to start by enabling window-select (for each object type: faces OR edges [these would need to be separated like requested here. EDIT: "Surfaces" would also need their own filter] OR features OR bodies) with no command active?
I'd like to be able to use it deleted multibodies from my browser menu...at the moment i have to select each one individually while holding down ctrl. When changes visual attributes of faces of parts in would be nice to use a window to select them all rather than select each face individually while holding down ctrl
