Select all function
Select all function
anthony_hendrick
Select all function
anthony_hendrick
Is there a select all function in Inventor?
For example, I am placing a lot of revision tags on my drawings.
I would like all these tags to be on a certain layer. I have to select the tags one by one and put them on the layer. It would be great if there was a function to select all elements at the same time.
thanks in advance!
swalton
Shift-Right Click in the Drawing environment will show some additional selection filters.
You should be able to change the default layer for the rev tags in the Style Editor.
Make sure to push these changes back to your Style Library, and into your template files.
Steve Walton
Inventor 2025
Vault Professional 2025
anthony_hendrick
Thanks very much sWalton, I will certainly check that out!!
