Sectioning in isometric view
manikandanmmkm
Message 1 of 11
manikandanmmkm
How to section a isometric view?
Is it possible in inventor drawing?
Replies (10)
Message 2 of 11
JDMather
Yes - it is possible.
You can have an off-sheet parent view to create an on-sheet child view.
Zip and attach your part or assembly and drawing files here if you can't figure it out.
Message 3 of 11
Cadmanto
Are you talking about something like below?  Understand doing this can give you some obscure results. 😁
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 11
johnsonshiue
Hi! I believe you are talking about showing a sectioned component in an Isometric view, right? If yes, you can create a section view first. Then create an auxiliary view or projected view. Is this what you were looking for?
Many thanks!
Software Test Engineer
Message 5 of 11
manikandanmmkm
No. I need section in drawing iso view looks like in assembly half and quarter section. Is this possible?
Message 6 of 11
JDMather
No files? No reference images?
AFAIK - What you want to do is very easy to do.
Message 7 of 11
manikandanmmkm
I want directly section in iso view (No need any ref. views) and i don't want project view. However we do section in .ipt & .iam like that i need in .idw (directly section in same view).
Message 8 of 11
JDMather
I don't know why you would put such limitations on documenting a design, but if you cannot live with a reference view off-sheet (or on-sheet) and you don't want to cut the model directly - then the answer is no.
Message 9 of 11
johnsonshiue
Hi! Indeed, like JD mentioned, such workflow (creating an iso section base view) does exist in Inventor yet.
Many thanks!
Message 10 of 11
mgrenier2
Man I swear, sometimes this software makes me want to smash my head through my screens while I bash it from behind with my keyboard.
Message 11 of 11
johnsonshiue
Hi! I am sorry that Inventor does not behave as well as it should. But Inventor isn't worth your strong emotion. Could you elaborate your frustration? I would like to understand the issue better and see if there is a workflow to suggest.
Many thanks!
