Section views with single part containing multiple solid bodies
I am searching for a solution for displaying color/textures when using a single part that contains multiple solid bodies.
Two instances that i am dealing with are as follows:
1 i-part with two members
The i-part when sectioned in a drawing shows all surfaces or solids as "generic" instead of the selected solid body color.
1 stand alone part.
The stand alone part when sectioned in a drawing shows the colors of each solid body with no problems.
It is my preference to have the colors shown in the section view regardless of if the part is a stand alone part or an i-part.
Is this possible or is this beyond the programs capability?
If something similar to this has been posted before i will gladly accept guidence to another post.
I am using Inventor Professional 2014 SP2
mdavis22569
Can you post the files (iam/ipt/idw)
Mike Davis
Attached is one of the i-parts
attached is one of the stand alone parts.
Another way to look at this may be: is there a way to default the section view in a drawing to display the body color/texture rather than the part color/texture? But keeping in mind if the part is a standard stand alone ipt there isnt an issue the section works perfectly. just a i-part section view changes to the part color/texture instead of the body color/texture.
