Section View not showing sectioned part on drawing (content center)
christophe.moerman.external
if you look closely, the holes are not visible in box cut HH. It is also strange that the holes in the middle are not visible, see section JJ:
Why no working? I use inventor 2019.
fix: nopes!
kacper.suchomski
Hi
The participants in the section (assembly or individual components) must be defined.
Kacper Suchomski
s_ciocca
Ciao  @christophe.moerman.external,
per questi particolari seleziona sul "browser albero modello" la parte interessata (quella del centro contenuti)...
poi tasto dx del mouse clicca su "partecipazione alla sezione" e poi clicca "sezione"
In questo modo vedrai i particolari in sezione (anche quelli del C.C.)
Stefano
it's solved. Thx. why not set by default?
kacper.suchomski
Often there is no need to cut profiles.
Kacper Suchomski
Yes, it is, but interesting for welding or drilling or placing sizes.
When I place the cross-section, it must be a complete cross-section. No half work or tinkering. It must be 100% correctly visible en important.
If you look at it, then I have the impression that it is a design flaw = confusion!!!!!!
I don't have time to adjust there.
Best regards
