Section view Frame Generator
YannickEnrico
Advisor Advisor
Message 1 of 11
YannickEnrico
Hello there.
After upgrading to IV2018, it doesn't seem FG parts are following the rules of sectioning anymore.
See attached.
As you can see, I have both settings on view and application options, and yet I still have to right click and choose sectioning.
Am I doing something wrong, or is there a bug in regards to this?
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Replies (10)
Message 2 of 11
mdavis22569
Hi @YannickEnrico
What do you have for Drawings, Section Standard Parts?
Mike Davis
Message 3 of 11
YannickEnrico
It's set to always as well.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 4 of 11
mdavis22569
I have seen this yet (not saying it isn't a bug ) ... Can you share the data set ?
Mike Davis
Message 5 of 11
YannickEnrico
A little closer to a solution.
Since I cannot share the data set, I tried to reproduce it.
I couldn't reproduce it with DIN Angle Steel.
I could however Reproduce it with DIN IPE steel. See attached Pack'n'Go Zip
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 6 of 11
mdavis22569
Am I missing something ... I did change the one section to section .. moved the section line all over and it keeps updating
Mike Davis
Message 7 of 11
salariua
You need to copy the family over to your library and replace family template.
There are a lot of CC items set not to participate in assembly and section views.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 8 of 11
salariua
Adrian S.
blog.ads-sol.com
Message 9 of 11
YannickEnrico
@mdavis22569 - The issue is that you have to right click every time, despite all settings. I know you can right click and make it work, but it seems unnecessary when you set it on application options level.
@salariua - So that means a hell of a work to do that, I suppose? Thanks for responding and shedding some light on this.
@johnsonshiue - Could you forward this to your developers?
It appears that application options does indeed work in regards to section views in assemblies.
It doesn't work in regards to section views in drawings.
Despite the options enabled mentioned by Salariua, Mdavis22569 and me.
Edit:
I'll accept @salariua's answer as solution, since that does indeed make it work. I'm fairly certain it's a bug that Application Options doesn't overwrite that, though
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 10 of 11
salariua
@YannickEnrico
I thought I've seen an ilogic, VB code around which can change this so you can use something like code injector or propagate it down from a higher up assembly but I can't find it and I am beginning to think I was imagining it.
Adrian S.
blog.ads-sol.com
Message 11 of 11
YannickEnrico
@salariua - I'll see how well I master my google search skills later on. For now, I'll have to use right click.
What's silly, though, is that I haven't experienced this in earlier versions.
Yes, if you hadn't checked off the application options option, it would happen. But after checking that, it stopped in earlier versions.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
