Dear all,
I need to draw a section view of a circular part with many holes on it.
The holes as the configuration that you can see in the pictures bellow (They are the same part).
In Inventor 2022 I just can use the Section line B-B (bellow left) but I would like to use the Section line that I sketched (bellow right).
When I select the sketch with the desired section line
(radial line + curve) appears the error message bellow.
Can anyone help?
The projection I want should just consider the green lines
