Search Path From Different Directory of Server
Hi Team,
I'm on a trial version of Inventor Professional. I need to open up a Creo assembly file but all sub-files are scattered in various path. Initially in Creo we use a Search.pro with following detail which can be opened by note pad:
X:\70_Creo
X:\70_Creo\LIBRARY\METRICLIB\AEROSPACE_FAST
X:\70_Creo\LIBRARY\METRICLIB\HEX_NUTS
X:\70_Creo\LIBRARY\METRICLIB\HEX_SCR_BOLT
X:\70_Creo\LIBRARY\METRICLIB\MACH_SCR
X:\70_Creo\LIBRARY\METRICLIB\RETAIN_RINGS
X:\70_Creo\LIBRARY\METRICLIB\RIVETS
X:\70_Creo\LIBRARY\METRICLIB\RND_HEAD_BOLTS
X:\70_Creo\LIBRARY\METRICLIB\SOCK_HD_SCR
X:\70_Creo\LIBRARY\METRICLIB\T_NUT_BOLT
X:\70_Creo\LIBRARY\METRICLIB\TAPPING_SCR
X:\70_Creo\LIBRARY\METRICLIB\WASHERS
X:\70_Creo\LIBRARY\eng_part_lib\tapping_scrw
X:\70_Creo\LIBRARY\tube_fitting
X:\70_Creo\LIBRARY\SHACKLE_SWIVEL_HOOK
X:\70_Creo\LIBRARY\metriclib\lock_nut_and_lock_washer
X:\70_Creo\LIBRARY\valve
X:\70_Creo\SV001\SV-001\SV-001
X:\70_Creo\SV001\SV-001\SV-002
X:\70_Creo\SV001\SV-001\SV-003
X:\70_Creo\SV001\SV-001\SV-004
So if i want to open an assembly files (with all sub assemblies in different folders) using Inventor, how do i do it?
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
In your Inventor active project file you need to use the "Workgroup Search Path" option.  I would suggest that you review this information: https://synergiscadblog.com/2014/10/29/why-its-important-to-have-an-organized-structure-for-inventor-and-a-properly-configured-project-file-part-2-of-2/
Mark Lancaster
So, i created a project file and i added the workgroup search path, but it still cannot call out all the parts and sub-assemblies.
Why is some of the workgroup search path turn red?
