Scaling a part in one axis
ToddPig
ToddPig
I have an extrusion that requires post machining.  The extrusion has a round exterior with various cutouts in the inside.  I have all the machine operations modeled (using iparts). The first articles came in slightly oval.  I would like to scroll up on the feature tree, use a scale command, and scale the extrusion in only 1 axis., then roll the tree back to the end.  This is something I am able to do in Solidworks, but can't figure out how to do this in Inventor
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
JDMather
If I follow your problem description - you should be able to use Scale in the Direct Edit.
ToddPig
JD,
That did it! (Weird that the Centroid would not default to the origin)
THANKS!!!
Inventor 2018
iParts = iHeadache
mcgyvr
I love Jeeps.. Smiley Wink
