Two questions
1. When upgrading from Inventor 2013 to 2015 what is the ideal way to save parts and assemblies from 2013 to 2015?
2. Projects - how do you set your projects.Do you have a separate project folder for each design ( example: a project file for each different machine type)
Best Regards,
Ray H
Are you using vault?
You can use the Task Scheduler and Migrate ..
You can let it migrate as you open and save files ...
However using the Task Scheduler to migrate is usually what I do ...
Projects are you referring to IPJ's ...
That's up to you and your company.
My work, we have 1 company wide IPJ, that is set up with all the standards we want everyone to use.
@Anonymous wrote:
Two questions
You don't really need to do anything other than open the 2013 files in 2015 and save. At that time Inventor will save them as 2015 files, and they won't be able to be opened in 2013 any longer. However, you might want to migrate all of your 2013 files to 2015, as it will make working with assemblies quicker.
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-FB9B4422-2348-46FA-964B-7845D9D96018
See this link:
Best Regards,
Ray H
I hope this helps.
Curtis
