Saving Multiple iPart iterations as STLs
So I've created an iPart with 9 different iterations in the table.  I would like to save them all as a different file type at once (STL).  How would I go about saveing all 9 iterations as separate STL files without doing it manually?  I am just being lazy, but it might be useful for some of the work I have to do later.
blair
Unless someone has written a specific iLogic code to open the file and step through each option and build the IPT, then export it with a sequential unique file name, then I would have to say, no.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
johnsonshiue
Hi! I think this can be done semi-automatically. You need to first generate the iPart member files (select all the rows under iPart table note -> Generate Files). Next, close Inventor and start Task Scheduler -> Create task -> Export to STL.
Many thanks!
Software Test Engineer
