Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
Saving Model Views
5 REPLIES 5
Cadmanto
6898 Views, 5 Replies
Saving Model Views
When you are spining your model around and have a specific view
that you want to show in the drawing, how do you save that specific view
so you can import it into the drawing?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
5 REPLIES 5
mcgyvr
in reply to: Cadmanto
Its done in the idw file..not in the model. Press the base view button in the idw file then press the (change view orientation) button right below the list of orientations (looks like a 3d box with a magnifying glass over it) to the left of the projection symbol. That will open the model and allow you to rotate/orient it how you want then press the finish custom view button and your view should now match what you wanted.
Hi Cadmanto,
In addition to creating a custom view via the IDW view tools, you can create Design View Representations in your model. Then you can specify those views when creating your drawing view.
Jonathan Landeros covers this in a couple of recent blog articles:
http://inventor-tales.blogspot.com/2011/12/view-representations-in-autodesk.html
http://inventor-tales.blogspot.com/2012/01/using-view-representations-on-autodesk.html
He's talking about this in regards to assemblies, but you can do much the same thing with parts (in later versions of Inventor).
I hope this helps.
Curtis
Cadmanto
in reply to: mcgyvr
Thank you.
Sorry it took so long to get back to this thread.
I discovered that this not only works with new views but you can also go back and select this button
I haven't tried it yet, but wondering if you do this with a parent view will aoo the projected views update as well?
Best Regards,
Scott McFadden
Yes, reorienting a parent view will change the following views as well.
Hey, I can answer a question once in a while!Smiley LOL
Cadmanto
Very Nice Jim!!!  Smiley Wink
Best Regards,
Scott McFadden
