Hi.
It is a drawing of an assembly with balloons?
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Are you referring to the initial save or a save after you already saved it?
If the former, that's how it works.
If the latter, I would start looking at read/write permissions.
Update: Sorry I read it as Save As and not Save As Copy.. Did you do something like this?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Is the idw file writable? If it is read-only or it is opened in a different session, it cannot be saved.
Many thanks!
Yes its an .idw with balloons. i have a feeling that the problem is caused when there is an interaction when i am using A360. Perhaps there is some sort of conflict. It never used to happen until i started to use A360.
Regards
I dont think its a problem with permissions.
Regards
This happened to me when i was editing the assembly and traying to save a drawing of this assembly at same time.
