Inventor Forum
Saving idw
8 REPLIES 8
Message 1 of 9
methoni
193 Views, 8 Replies
Saving idw
When i try to save my idw i get save as copy, why cant i just save.
Any suggestions please
8 REPLIES 8
Message 2 of 9
Fouad-l
in reply to: methoni
Hi.
It is a drawing of an assembly with balloons?
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
Message 3 of 9
Mark.Lancaster
@methoni
Are you referring to the initial save or a save after you already saved it?
If the former, that's how it works.
If the latter, I would start looking at read/write permissions.
Update:  Sorry I read it as Save As and not Save As Copy..  Did you do something like this?
Mark Lancaster
Message 4 of 9
johnsonshiue
Is the idw file writable? If it is read-only or it is opened in a different session, it cannot be saved.
Many thanks!
Software Test Engineer
Message 5 of 9
methoni
in reply to: Fouad-l
Yes its an .idw with balloons. i have a feeling that the problem is caused when there is an interaction when i am using A360. Perhaps there is some sort of conflict. It never used to happen until i started to use A360.
Regards
Message 6 of 9
methoni
in reply to: Mark.Lancaster
I dont think its a problem with permissions.
Regards
Message 7 of 9
Fouad-l
This happened to me when i was editing the assembly and traying to save a drawing of this assembly at same time.
Message 8 of 9
methoni
Yes its possible that's the problem that can happen ,but in this case its just purely a .idw drawing, ie there is no model.
Regards
Message 9 of 9
kpyoung333
How/what are you ballooning with no model?
