Savecopyas via API clears undo stack
TA.Fehr
TA.Fehr
When I manually save a copy as, I can retain my undo history. But when I call the same command through the api
oDoc.SaveAs(SaveName, True)
It saves the copy, but deletes the undo history. Is there a way to not have this happen?
TA.Fehr
Sorry, my mistake. There was another code calling some modifications to the saved file. These saves, although happening in the background were actually causing the active document's undo stack to clear.
