Save standard iPart members in same directory as factory iPart?
francesco.dinh
francesco.dinh
Everytime I create a standard iPart member from its factory, say something like
C:\stuff\myiPart.ipt
the default save directory is a subdirectory with the iPart factory name:
C:\stuff\myiPart\myiPartMember.ipt
is it possible to avoid this, and to save the created iPart in the same directory as the iPart factory?
Thanks!
Xun.Zhang
Hi Francesco,
Unfortunately, it seems impossible right now. Maybe Pack & Go can make the hierarchy more flatten.
Sorry for that.
Xun
johnsonshiue
Hi Francesco,
It is still doable. Please refer to the following old thread.
https://forums.autodesk.com/t5/inventor-forum/turn-off-ipart-children-folders/td-p/2229415
Close Inventor.
Execute regedit.exe in a command line.
Go to ->HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionxx.0\System\Preferences\Catalog\
(Please note, "Catalog" may not exist; create one manually)
Add a DWORD, "FlatStructure" and set the value to 1.
Restart Inventor.
It should work.
Many thanks!
Software Test Engineer
francesco.dinh
Thank you John! Unfortunately that's kinda hacky and I don't think IT is going to accept working with all the network pc's regedits (those are parts that will be shared on the vault). I hope Inventor will implement it as an option in the part settings!
johnsonshiue
Hi Francesco,
Indeed, this is a hack. iPart was designed to have sub folder structure. This particular setting was added a few years later after iPart workflows were introduced. If this is something you want to have in Inventor, please submit an idea on Ideas forum and let other users vote for it. The ideas are being actively reviewed on a daily basis.
Many thanks!
