Save New Positional Representation as Master?
TomBarosso3248
TomBarosso3248
Hi-
I have four position representations of an assembly, the master and three "new" positions.  The master position is no longer relevant to what I'm working on so I'd like to save one of the new positions as the master.  Is there an easy way to do this or do I have to go through all of my constraints in the master position and modify them individually to match the desired position.
Tom
I'm not sure if this is what you mean but if it is just that you don't want to see the view you can suppress it in the model tree and It will still be there but you will not see it on the drawing. The other projected views will still be visible.
TomBarosso3248
Thanks, but I was referring to the assembly view rather than drawing view.
johnsonshiue
Hi! We have heard this request before. Indeed, currently you could save activate PosRep:non-Master in subassemblies and then save the state in PosRep:Master at the top. However, if you want to override individual PosRep item at top-level, you will have to create a new PosRep. PosRep:Master usually mean there is no override.
Many thanks!
Software Test Engineer
