Inventor Forum
Save Copy and Replace tool now available
12 REPLIES 12
Message 1 of 13
483 Views, 12 Replies
In response to popular demand, I have posted a "Save Copy As and
Replace" tool to:
http://www.cbliss.com/inventor/iCode
It is a macro so you can load and run with Mr.Macro (on the same page).
This tool is pretty basic but it does seem to do the job. Basically, you
pick a part/subassembly in the browser or graphic window, provide a new
name and it creates the copy then replaces the selected one in the
assembly. Optionally, it will replace all instances in that assembly.
If there is enough interest, I will expand its capability and make it
into an add-in.
Credit where credit is due, the foundation came from Kevin Schneider
from a little program posted on mymcad.com
12 REPLIES 12
Message 2 of 13
Works fine, Charles! Thanks!
Alpo
Message 3 of 13
Hmmm.
I cannot seem to get it to work properly.
When I "select component to replace", I get "Runtime error 91". The error
points to :
sFullFileName = oOccurrence.Definition.Document.FullFileName
mail me if you want me to test further.
But it will be great to finally get this functionality. If you decide to
expand it, could you think about include a proper saveas-feature:
SaveCopyAs-CloseDocument-OpenSavedCopy
Jorgen Bjornes
Visit the Scandinavian Discussion-forum
For Inventor at www.bjornes.org
Message 4 of 13
I seem to be having the same "Runtime error 91" as Jorgen.
Regards
Matt Hutchinson
Message 5 of 13
Hi Charles,
Could you please read the post "Demote - Wish" I created at 22-9-2003,
13:54.
Is there any way you can keep all the constraints when you turn a (single)
part into a (single) assembly.
Dennis Jeffrey says he can do it without losing constraints, but I can't 😞
The "Save-Copy-As, Close-Document, Open-Just-Saved-Copy" option also sounds
good...
Keep up the good work!
"Charles Bliss" wrote in message
news:3F6E5C7F.9040608@cbliss.com...
> Replace" tool to:
> into an add-in.
Message 6 of 13
What type of entity are you picking? I would expect the filter to only
allow a properly selected part/assembly file.
Jorgen Bjornes wrote:
> Hmmm.
> error points to :
> to expand it, could you think about include a proper saveas-feature:
Message 7 of 13
A while back I posted some code that does this with template files, I doubt it would take
much to make it work with other files.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Teun Ham" wrote in message
news:CB826A175E606647252D8F238019F82B@in.WebX.maYIadrTaRb...
> Hi Charles,
> 13:54.
> good...
Message 8 of 13
Please make it an add-in. I think many people have requested this functionality
from autodesk for awhile now.
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
> Replace" tool to:
> into an add-in.
Message 9 of 13
On Mon, 22 Sep 2003 08:15:34 -0700, Charles Bliss
I was picking a part in an assembly document.
Jorgen Bjornes
Message 10 of 13
I will work some more on it. I saw that happen once yesterday but was
unable to trap it.
>> only allow a properly selected part/assembly file.
Message 11 of 13
On Tue, 23 Sep 2003 07:52:44 -0700, Charles Bliss
> unable to trap it.
Please let me know if I can help you locate the problem.
It's quite consistent here! (although I have not tried in many assys).
If I find some pattern, I'll tell you.
Jorgen Bjornes
Message 12 of 13
Hi Charles!
When I removed these three lines from Form "frmSaveAsReplace", it started
to work OK:
Private Sub UserForm_Activate()
cmdSelect_Click
End Sub
Alpo
Message 13 of 13
Hmm, a timing issue. I put those lines in at the last minute thinking
that it would be more user friendly if it started out by selecting. It
is safe to remove them except you will have to hit the select button to
select the part before proceeding. Thanks for the heads up.
Pelus wrote:
> Hi Charles!
> started to work OK:
> cmdSelect_Click
> End Sub
