Hi Charles,
Could you please read the post "Demote - Wish" I created at 22-9-2003,
13:54.
Is there any way you can keep all the constraints when you turn a (single)
part into a (single) assembly.
Dennis Jeffrey says he can do it without losing constraints, but I can't 😞
The "Save-Copy-As, Close-Document, Open-Just-Saved-Copy" option also sounds
good...
Keep up the good work!
"Charles Bliss" wrote in message
news:3F6E5C7F.9040608@cbliss.com...
> In response to popular demand, I have posted a "Save Copy As and
> Replace" tool to:
> http://www.cbliss.com/inventor/iCode
> It is a macro so you can load and run with Mr.Macro (on the same page).
> This tool is pretty basic but it does seem to do the job. Basically, you
> pick a part/subassembly in the browser or graphic window, provide a new
> name and it creates the copy then replaces the selected one in the
> assembly. Optionally, it will replace all instances in that assembly.
> If there is enough interest, I will expand its capability and make it
> into an add-in.
> Credit where credit is due, the foundation came from Kevin Schneider
> from a little program posted on mymcad.com
