Save As Prompt on New Part creation
jbegg
jbegg
I have Inventor 2019.1.2.  When I create a new part, I am immediately prompted to Save As.  This has just started happening and I cannot find where the setting is to stop this.  Any and all information will be greatly appreciated.
Procedure I'm following and settings
Application Options:
Startup
Startup Action -->File New Dialog
____
Standard.ipt  <Create>
Save As dialog appears.
mcgyvr
Go to manage tab and hit the Event Triggers button in the ilogic section..
In the "rules on event" section do you see any rules assigned to specific triggers.. (like new document,etc...)
Make sure to check not only the  This document tab but the others too..
Its highly likely that your cad manager/boss or whatever has created an ilogic rule to immediately prompt to saveas on the new document trigger..
jbegg
I checked the Event Triggers and did not see anything that was editable that I could change. See picture.
Cadmanto
This is a little different then what you are experiencing, but look at this idea.
https://forums.autodesk.com/t5/inventor-ideas/stop-telling-me-i-need-to-save-something-i-haven-t-cha...
See if this link speaks to anything that is going on with your file.
https://forums.autodesk.com/t5/inventor-forum/prompt-to-save-files-that-did-not-change/td-p/5942705
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
mcgyvr
What about the "this document" tab...and all the other tabs?
Can you please attach your template file here? (zip it first)
jbegg
Thank you to mcgyvr and Cadmanto for looking into this with me.  After looking at what they were pointing out, it appeared that an add-in was hijacking the new File dialog.  I had the Xometry add-in for quoting start up with the Inventor load.  What this was doing was basically telling Inventor that the file had already changed and it needed to be saved.  Turning off that Add-in solved the problem.
I have contacted Xometry with the issue and hopefully they'll write up a patch.   thank you again to mcgyver and Cadmanto and the forum for the support in solving this issue.
