Sample Point Cloud data for inventor import
Hello
Just seen a handheld scanner & would like to known what a scan would look like in Inventor.
Had a search for sample files & can't see typical industrial plant - buildings, quarries, cuddly toys a plenty.
Ideally a machine tool  a few meters square would be grand.
What tips can you share about importing point clouds into inventor?
Can you upload a sample data set please or point to a decent scan to look at?
Many Thanks..
asiteur
I am not sure how much this functionality is used in Inventor.
For sample data I would suggest to pose the question in the Recap forum as those users work with Point Clouds, I'm sure there will be some who are willing to share something, or know where to find great samples;
https://forums.autodesk.com/t5/recap-360-forum/bd-p/451
When importing Point Clouds in Inventor I would suggest to use the ReCap import method over Excel as large excel sheets in Inventor tend to slow things down a lot.
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
blandb
If you have recap installed, you can search for ".rcp" on your C or where you installed the software. There is a sample recap file you can use and import into inventor.
C:\ProgramData\Autodesk\Autodesk ReCap 360\Sample
Hope that helps.
Autodesk Certified Professional
kennyj
Hello @Anonymous,
Scan data is used quiet often in Inventor; from land survey scans to industrial piping layouts to individual parts for reverse engineering.  Parts that are related but not needed for an assembly are often scanned and placed to show relationships, etc. for presentations, etc.  Note that scan data does not show up in drawings and currently there are no good "scan to model" options if you are thinking you can just scan it, then convert it to a 3D model.  There are a lot of passable Scan to Surface or Scan to Shape 3rd party programs/plug-ins; but from my research and experience even these will require a lot of clean-up and model rework/corrections before you can use them.
Unfortunately Inventor dropped the ability to pull scan data straight in (after 2013, I think); you now have to go thru ReCap to convert the data into something Inventor can import.  As posted above, ReCap has several sample files you can look at.
What it actually looks like depends on your settings - you can use the photo feature of your scanner to place the correct color on the point cloud, or you can use the default intensity setting (the closer to the scanner the color changes to give a gradient color affect), etc.  Also there are options for all black, etc.
Once in Inventor, the point cloud acts much like a part - but with limited editing abilities.  So you can place your scan in an assembly to see the parts in place, or you can derive parts into the scan, etc.  The settings allow you to set how many points you can see, how large the points are, etc.  So the look of a single point cloud can vary drastically based upon user preferences or intent of the data.
I suggest, as suggested above, that you explore ReCap since it will go hand-in-hand with your Inventor scanning.
Hope this helps,
Kenny
