Runtime Error! R6025 - pure virtual function call - Inv 2015 Pro
Error occurs when checking the assembly  into Vault 2015 R1.
Top Level Assembly, most likely corrupted?
Software :
Inventor 2015 - Seems to be up to date.
Vault Professional 2015 Build 19.1.13.0
Mark.Lancaster
@Anonymous
Can you confirm if you have at least Inventor 2015 SP2/Update 2?  For Inventor 2015, there is SP2 and Update #5.
Mark Lancaster
Build: 223, Release 2015 SP2 Update 5 - 04/29/2016
Sorry for not confirming in the previous post.
Update.
Had the error on a lower-level sub-assembly - but somebody else was working on a sub-assembly of the sub-assembly.
After closing and undoing the check-out the error seems to have been cleared up on both assembly files.
Marking the issue as resolved.
Thanks for reading.
