run a rule when a parameter change
Torben.pedersen
Message 1 of 19
Torben.pedersen
hallo there
I what to make a rule, that updates / run automaticaly when the diameter change here is an exeampel:
if Dia1 change then
run rule BT
end if
I know I´m not using the right terms, thats why I need some help 🙂
hope this makes sense to you, or else feel free to ask questions 🙂
I hope this was helpfull.
Did I answer your question please accept this as solution.
if you liked my answer feel free to give me a Kudo 🙂
Replies (18)
Message 2 of 19
Thomas_Savage
Could you attach your file so i could have a look?
You could create a rule so when DIA1 is a certain size, or more, less than a certain size, it will run a rule.
If you attach your file i will show you what i mean.
Thomas.
Thomas Savage
Design Engineer
Message 3 of 19
Torben.pedersen
I'm afraid I can´t attach the file or I'm not allowed. ( furthermore the parameter name´s are in german )
I know I can set i up like you explained, but that´s not what I need.
I need the rule to do as previously explained, is that not possible or  is the only way to do as you described? 🙂
Message 4 of 19
Thomas_Savage
Yes you could do it.
But without looking at your part it is harder to create a rule.
What i was saying in my previous post is. You need to specify what size the the dia changes to, to run rule.
So you could do something like this:
If Dia1  = 20 Then
iLogicVb.RunRule("RuleName")
End if
If you don't specify a size of diameter, how will it know when to run the rule.
And place the rule you want to run in ("RuleName")
You could put any size you want, i just put 20 for an example.
you could also do < > before the = so it is more or less the size.
Hope this is what you mean?
Thomas.
Thomas Savage
Design Engineer
Message 5 of 19
Torben.pedersen
so could I do somthing like this:
If Dia1  < (less then) 9999999999999999999 Then
End if
and then every time I change Dia1 and it´s less then 9999999999999999999 mm the rule runs?
Message 6 of 19
salariua
is this what you are after:
Check my attached part made in 2017.
I have created a "Check" parameter and when diameter is different than check value it will run the second rule and update the check.
First rule
If Parameter("Check") <> Parameter("Dia") Then
	iLogicVb.RunRule("DiaChanged")
Second Rule
Check = Dia
InventorVb.DocumentUpdate()
MessageBox.Show("dia changed to: " & Dia , "i")
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 7 of 19
Thomas_Savage
Like this:
If Dia1  <  = 9999999999999999999 Then
End if
Try it and let me know how it goes.
Thomas.
Thomas Savage
Design Engineer
Message 8 of 19
Thomas_Savage
I forgot to put the update as well.
End if
Thomas.
Thomas Savage
Design Engineer
Message 9 of 19
Torben.pedersen
Hallo thomas
thanks for your help and feedback. It worked
Message 10 of 19
salariua
Wouldn't this be TRUE all the time not just on diameter change?? so the rule will run every single time rather than just when diameter changes?
Adrian S.
blog.ads-sol.com
Message 11 of 19
Thomas_Savage
You're welcome.
Glad it worked.
Thomas
Thomas Savage
Design Engineer
Message 12 of 19
Thomas_Savage
I am sure it would only run the rule when the diameter is changed?
So if you don't change the diameter, it will not run the rule.
I usually use the more, and less than and it only runs the rule when i change the size.
I am not on a computer with Inventor at the moment. So cant test it.
But i am sure it will not update until the diameter is changed.
Thomas
Thomas Savage
Design Engineer
Message 13 of 19
Torben.pedersen
the rule will only look at the Dia1 when it change I guess, and that is what I need
Message 14 of 19
salariua
well... if you are happy... so are we.
you need to limit the number of digits on 999999 check or you will get an error
keep in mind there is a limitation with this and that second rule will run sometimes run even if diameter has not changed...
Adrian S.
blog.ads-sol.com
Message 15 of 19
Torben.pedersen
yeah I found out with the digits, I set it to 20 because it will never be more than around 10 and not under 1,5
so I could also change the rule to only be active between those numbers
Message 16 of 19
Torben.pedersen
the rule looks like this now:
SyntaxEditor Code Snippet
If BB <= 20 Or BB >= 1 Then
iLogicVb.RunRule("BT")
Message 17 of 19
Thomas_Savage
Yes i usually use less then a size, and more than a size.
Your rule looks good.
Thomas.
Thomas Savage
Design Engineer
Message 18 of 19
Torben.pedersen
cool thanks for the help, I really only need a push in the right direction, and the it comes to me 🙂
Message 19 of 19
Thomas_Savage
You're welcome.
Thomas Savage
Design Engineer
