Roundings
Roundings
d_sandach
Message 1 of 10
Roundings
d_sandach
how can these roundings be removed?
Replies (9)
Message 2 of 10
CCarreiras
Hi!
Delete it..
Place the part and we show you.
CCarreiras
Message 3 of 10
d_sandach
I would like to cut out the roundings where there are "X" signs, but leave them in the place where the "correct" sign is, what option should I use, because I'm looking for it but I can't find it
Message 4 of 10
henryjoseph9804
Is this supposed to be a sheet metal part?
Message 5 of 10
d_sandach
Yes
Message 6 of 10
CCarreiras
Like i said... delete it..
If you place here the part, instead of images, it will be easier to help you.
CCarreiras
Message 7 of 10
d_sandach
I'm sorry, I didn't read about sending the part, here it is:
Message 8 of 10
CCarreiras
The way you're modelling is a mess...
Try this technique in the video: using Unfold Refold will prevent all those issues you're finding by cutting.
CCarreiras
Message 9 of 10
CCarreiras
After you create all the cuttings you need, refold the part... and then you will have the flat pattern you need.
CCarreiras
Message 10 of 10
d_sandach
thank you very much for your help
