Just to confirm, i can't round a parameter that contains an Angle.
Is it correct that you can't round parameters that contain anglulair unit's?
Solved by Frederick_Law. Go to Solution.
English version of the the previous answer: Tools -> Documents Settings -> Units -> Angular Dim Display Precision
Thanks for your reply, but this is unfortunatly not the awnser i'm looking for. An example in picture, I need this 5,555 deg to round to nearest full degrees. But using the round(), ceil() and floor() commands don't work in a parameter with the unit degree.
I could follow these steps. But the 5,555 stays 5,555 for some reason.
Not sure if relevant, but fyi i'm using Inventor 2021
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-EE98BCED-5623-4E3B-9E98-432C6738B081
floor, ceiling, round are unitless. It won't work on anything with unit.
