Rounded/Tapered holes not appearing in drawings
I'm designing a plate with an array of holes of different sizes and depths. Some of the holes are straight edges, some of them are tapered with rounded edges. The holes which are tapered with rounded edges are not appearing when I try to draw the model, presumably because there is no hard edge. Is there any way to override this?
I've attached some images for your info.
Thanks in advance!
Cadmanto
In your drawing, try editing the view and going to the display tab.  See if turning on the tangent edges displays them.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
It worked, thanks.
