Is it possible to rotate view during ALT+drag constrain? Neither 3d mouse or F4 doesn't work.
Solved by mikko.m. Go to Solution.
Solved by Xun.Zhang. Go to Solution.
Hello Mikko,
I am sorry, it seems impossible so far. The reason more like the key "Alt" hold on locks every operation up, you have to terminate the alt drag operation before any other operation.
Hope it helps!
Ok ,thanks. There is an idea now:
https://forums.autodesk.com/t5/inventor-ideas/rotate-view-during-alt-drag-constrain/idi-p/7943791
