Rotating Cylinder Inside Another Cylinder Dynamic Sim
Message 1 of 8
Hey everyone,
I'm kind of new to Inventor simulations and I think this might be just a quick fix.
I have an inner shaft and the outside case of a motor, as the shaft rotates in one direction the case should rotate in the opposite direction. I can get this to work in the assembly using a motional constraint no problem but when I port it to dynamic sim they wont rotate together like that. What am I missing?
Thanks in advance and I have attached the .iam file.
Best Wishes
Replies (7)
Message 2 of 8
chenj
Parts are missing from your attachment. I simply do a dynamic simulation in Inventor 2022, see the attachment.
Message 3 of 8
Thanks for getting back to me,
I've downloaded your simple system and will try to see what the difference is.
I've attached the parts I used and the assembly again. Let me know what you think.
Thanks again
Message 4 of 8
I see that you basically imposed two counter motions on the cylinder and shaft but is there no way to make one respond to the other?
Message 5 of 8
JDMather
@Anonymous
See Attached.
Message 6 of 8
Thanks for helping me with the solution!
This works perfectly, never would have occurred to me to make a dummy sketch and add two joints. Really appreciate it.
Also really enjoy your youtube content, have learned a lot.
Best Wishes
Message 7 of 8
JDMather
Another "solution" would not require the dummy part.
Simply use the Input Grapher to make the Imposed Motion of one of the Revolution Joints a ratio of Imposed Motion on the other Revolution Joint.  Actually, now that I think about it - it is even easier than that.  Don't need to use the Input Grapher.  Just set the ratio in the Imposed Motion.
Message 8 of 8
cuiken
How two parts rotated?
I have one part rotate and one part moved.
See attachment.
