rotate a part in an assembly
How do I do this? I need to rotate a part 30 degrees. The part is grounded.
thenottakenname
I would suggest avoiding grounding parts if you're able -- you'll have much more flexibility constraining origin planes. That said, unground your part, mate constrain two of the planes, and use a rotation constraint on the third plane to rotate it about that plane's axis.
Hope this helps!
Aaron Wilson
Inventor Professional 2022
AutoCAD 2020
JDMather
Unground it.
I suspect there is far more to the issue than this.
Can you Attach your assembly here? (or at least an image)
Here are the assembly and drawing. I need to rotate the sleeve 30 degrees clockwise
JDMather
See Attached logic.
Thank you for your help. I appreciate it.
thenottakenname
Just as a friendly reminder, you should mark the post that is the solution as the solution, instead of your own, so that others with the same questions can easily find the answers.
Aaron Wilson
AutoCAD 2020
