i have a weird problem in one of my drawings. When I open the IDW, all the sheets are looking directly at the sheet face. However, somehow in one of the sheets the editor is showing an edge-on view of the sheet - I just see a single line representing the height of the sheet. Sort of like I am looking at the sheet from the side instead of the front. I cannot seem to get it to look at the front of the sheet. The "Zoom All" button on the navigation bar, which has tool tip that says Zoom All is same as "Home" does not restore flat on view. F6, shortcut for home view in other environments, also does not work.
I didn't even know you could rotate a sheet in 3d in the idw environment.
Anyone know how to restore front view?
See below:
