Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I am new in using sheet metal.So far i am able to form a cylinder made out of sheet metal and i am able to unfold it.The only problem is i want the two ends of the flat sheet to overlap so that it can be bolted together like a lap joint orientation .Is there anyone that has any suggestions how to perform this function using metal sheet ipt?
Regards
Didi
Solved by JDMather. Go to Solution.
Solved by IgorMir. Go to Solution.
Hi Stuart,
Would that model be acceptable for your needs? Please see the attached IV2010 file.
Igor.
@Anonymous wrote:
Hi
I'm trying to do exactly this too but when I go to Flat Pattern it doesnt flatten the cone.
Any help would be really appreciated as ( appearing ) not to be able to add a flange to a cone with a Contour Roll is really frustrating.
Regards
Stuart Wood
Using Inventor 2016
Windows10
Dell T5500
32GB Ram
Nvidia Quadro 4000
Hi
Thanks for the quick response.
That's not quite what I had in mind as I really wanted to get the sheet metal joggle on the edge, but it has prompted some thoughts and I can see how your process.
I'll try to have a look at it later today....hopefully and report back.
Many thanks
Stuart
