Robot Simulation
Robot Simulation
manan
Message 1 of 8
Robot Simulation
manan
Hi
Working on a project where I have to simulate a robot movement to pick up an object and drop it into a bin using Autodesk inventor. Is there a way to do Kinematic simulation in the software and achieve the above statement?
Thanks in advance
Regards
Manan
Replies (7)
Message 2 of 8
JDMather
Yes, my students do this in Environments>Dynamic Simulation.
Attach your assembly here.
Message 3 of 8
manan
Thanks for the reply. link for the robot file:https://workdrive.zohoexternal.com/external/5HWqkrm9Iit-M4Xzc
Wanted to check if the robot can pick something and move in a linear path using Dynamic Simulation
Message 4 of 8
JDMather
@manan wrote:
...link for the robot file
Place all files (*.iam and *.ipt) into a single folder.
Right click on the folder and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
STEP files are not iam or ipt files with assembly constraints.
Message 5 of 8
manan
Sharing you the file requested
Message 6 of 8
JDMather
Have you ever used the Input Grapher in Environments>Dynamic Simulation to control Joint Positions?
Message 7 of 8
david.kirschner07
I would be really interested of the outcome of this thread. I would like to do similar stuff just with a delta robot, then check the forces/torques it exert on the frame so I can continue with stress/modal analysis.
To your question @JDMather : the problem with the Input grapher that I do not know the joint position of each driving joints, because I would need to solve the Inverse kinematics problem for that, right? Without additional simulator to generate the joint position for every driving joint how could I "control" the end effector of the robot on a desired trajectory?
How would the workflow look like?
Thanks for you help in advance!
Best regards,
David
Message 8 of 8
JDMather
