As said in the title, the RMB is not working in IDW/DWG enviroment when right clicking on Leader Text and Baloons.
After reading older posts tried updating and uninstalling 3dConexion drivers without any results.
Running Inventor 2024.0.
Solved by florescu.d95. Go to Solution.
1st, I'd update to 2024.3, may not help much, but stranger things...
Next, I'd check if the mouse needs an update driver (is it a 3DConnexion as well?)
If it's a wireless mouse, check the dongle on another system. I've had those fail numerous times.
A simple nudge can render them useless.
Jim O'Flaherty
Hi! Please make sure all critical Windows updates are installed and the graphics driver is updated. Also install the latest update to your Inventor release.
Are you using dual monitor? Can you make the monitor you focus more as the main monitor?
Many thanks!
Hi @johnsonshiue,
Everything was updated apart from Inventor.
Running the Inventor Reset Utility fixed it.
Daniel
