Right click visibility toggle is now Alt+V?
millejm85
millejm85
While in an assembly I can right click a part in the modelling window and V key is visibility toggle yet right click in the model tree and Alt+V is required, BUT if I right click in the model tree and hit V fast enough that works. Seems inconsistent.
Is there a setting I'm missing requiring me to use Alt+V now?
Upgraded from Inventor 2015 to 2018 recently, noticing some changes...
Inventor 2013 x64 sp1.1
Workstation Specs:
Dell T7500 Dual Xeon E5620 @2.40Ghz 8GB Ram
NVIDIA Quadro FX580 4GB, Windows 7 x64 sp1
-Overall choppy performance, expected better.
johnsonshiue
Hi! Have you installed the latest update (2018.2)?
Many thanks!
Software Test Engineer
martin.jacko
I played with it and I found that you are right.
It looks like issue.
As you can see on right image sometimes there is focus on menu (some commands have underscore character) so when you press V visibility is changed.
Martin
millejm85
Yes, I am running 2018.2
I now see that Free Move and Visibility share V, maybe this is the cause? I am using the "default multi character command alias" in the keyboard shortcut menu.
Found this issue when looking into this: https://forums.autodesk.com/t5/inventor-forum/free-move-visibility-bug/td-p/7534993
Workstation Specs:
millejm85
Thank you for seeing this Martin. Does Autodesk plan to track and attempt to resolve this issue?
Since posting this I have run into this problem constantly. Now instead of using RMB -> V, I have trained myself to scroll down the menu and select Visibility to toggle so it is consistent. With Visibility being one of my most used commands this has slowed me down a bit.
-James
Workstation Specs:
johnsonshiue
Hi! Yes, the issue is being investigated by the project team. We don't have a good solution yet.
Many thanks!
